How about this? A panel at a downward angle (to avoid debris collection) and velocity stacks in the main box. Air feeds would go to the front of the box to balance the air feed. Still a more complicated setup than the cones and not easy to get to the filter.
Air filter suggestions
Yeah, I know it's pretty far back, so I tried to keep it pretty high. Water was the big issue with the original roof vent concept. This should be a good compromise.Originally posted by slowautoxr View PostYour location is not the cleanest location to draw from. I'm glad you're paying a lot of attention to filtration.Matt W.
I've found some good foam filters from Perrin and am considering going that route. Really thick single stage foam that's removable for cleaning. The panel concept is just getting too complicated.Matt W.
