Anyone have some good data on this topic?
I need a short-style cone filter for my application. Would you recommend a dry filter, oiled cloth (K&N) or an oiled foam option?
This is for the Beetle. There are two NACA feeds from the rear quarter windows that feed an airbox mounted at the firewall (in the rear). In the airbox there are two 3" intake pipes that need something on them. The pipes go straight to the TBs.
So, the intake is about 4' in the air, but also halfway down the car.
As we all know, Shag Bark can be quite dusty. It sounds like all of the options have downsides ... paper can tear if not replaced often or in heavy dust environments, oiled cloth tends to let more dust through in any scenario but is not likely to fail, and the foam filters are great for dust but water tends to be catastrophic.
I'd love to have some input. Thanks!
Just looking around for affordable options, I found the Spectre brand stuff at Advance for around $20 for the dry filters or oiled cloth versions. The foam ones from SI are $15 ... http://www.siliconeintakes.com/produ...8884de7663df49. Of course, K&N is an option (I heard they were developed originally for motorscross use), but I'm not sure they are worth 2x the cost if they don't filter better. As we all know, K&N advertises horsepower, not filtration.
