I'm debating on what size tire to put under the M3 for the season. I have a set of 17x9" wheels coming in soon and it's about time to order tires. I plan on sticking with Hankook RS3s for the first part of the season with a possible switch to the Rivals once those are released. The RS3's are literally $8 more for the set of 255/40s versus 245/40s. That's $8 total, not per tire. I want to stick with the RS3s over the ZII right now for money savings and track day use.
I've talked with the wheel supplier and I should be able to fit 255 tires with my current modifications. This will be a square setup on the car, no stagger. However I've read some articles where certain cars were faster with a 245 on a 9" wheel versus a 255 on the same wheel. Then on the other hand the guy that won STU at Nationals last year was running 255s on an M3. Perhaps the taller 255 tire helps with the gearing some as well.
So what sayeth the ALSCCA crew, 245/40s or 255/40s on a 17x9" wheel?
