I just got an open differential 1999 Miata. What are your suggestions for a LSD? Should I get a 4:10 torsen from a 94-97, a 4:30 torsen from a 99-00, add an obx or torsen unit to my current diff, other? Let me know your thoughts.
1999 Miata LSD Options
What years is you Miata? Never mind I see it's a 94 in your sig. Did you get axles with the open diff? 94 axles won't fit a 99 diff,Originally posted by jreynold View PostI just got an open differential 1999 Miata. What are your suggestions for a LSD? Should I get a 4:10 torsen from a 94-97, a 4:30 torsen from a 99-00, add an obx or torsen unit to my current diff, other? Let me know your thoughts.
If it's a 99 open diff I'd say its got a 4:30 gear so, go buy your self an OS Giken diff and enjoy life to it's fullest. ($1600.00 +set up fee)
The easy button would say to purchase a 99-05 Torsen diff complete and sell the open diff. After finding a good Torsen unit ($350) and then getting it set up ($150-$400) you'll have nearly as much in it as buying a good used 99-05 ($850 with axles+driveshaft) from a reputable salvage yard. Like The PartsGroup.John W8
An RX-7 clutch-type LSD might be an option as well. Check out Randy Stocker's info:
Andy Tow
ND Miata
Eliminator V2 - Sold-
Good luck finding one of those. Darryl looked for a long timeOriginally posted by jatow View PostAn RX-7 clutch-type LSD might be an option as well. Check out Randy Stocker's info:
www.solomiata.com/Drivetrain.htmlJohn W8
It needs to be a 86 or newer and out of the correct car to be a clutch type. The 85 diff will fit but doesn't have any way to lock the axles in (no cir clips)
