Miata Upper Ball Joint Boots
  • Miata Upper Ball Joint Boots
    I know there are a few Miata experts around...
    Has anyone purchased and installed upper ball joints boots recently?
    I just received a set today from Mazda. They look too small, more like a tie rod boot. I double-checked the part number in the catalog and crash manual to confirm that the number is correct. Also, there is a metal ring molded into the rubber with no large (external) metal ring. This makes them look even more like a tie-rod boot.
    Any similar experiences?
    Thanks,
    Todd
    Call Marshall at Med Center Mazda.
      The part number I came up with is mazda # 902-270 fits 90-05 models.If thats the part you got just knock the joint loose and put the boot on.
        Was too simple!!!
        One tap with a hammer and chisel to remove.
        Less than a minute to press on with a 32mm socket.
        The threads on Miata.net make it seem like a lot of work.
        Todd
          It aint no big step for a stepper.
            Originally posted by toddgreene View Post
            Was too simple!!!
            Todd
            I have learned over the past several years that what ever they say on the intertubes divide by 5 and you have a closer estimate on time. Miata net say 6-8 hours for a clutch and we all know that ain't so.
