There is a tech sheet in the PDX/CT Driver's Information Manual available on SCCA.com. The Tech Sheet is designed to help you check over your car for track use. the tech card you get at Registration is to tell Tech that you have actually registered and used to tart the process of issuing you a Tech Inspection Sticker
Do you have matching safety equipment on the passenger side of the car? I ask that your instructor have the same level of safety equipment as the driver. I will be bringing in car communicators so talking with your instructor while on track.
Yes indeed I do. Current setup is two matching kirkey 20* layback seats with non matching covers(passenger side has kirkey cover and the driver side has a diy sewing machine special), both sides have 4 point harnesses, rollover protection as seen in picture above, I have two SA 2010 helmets, one med and one large, and I also ordered two new sets of arms restraints for both sides of the car and they should be delivered today. Am I missing anything?
Brandon Roberts
Lotus Seven replica - Yamaha R1, book chasis
Lola T-640/644 - GSXR 1000
Extreme Kart - Briggs & Stratton World Formula
Birel B25 - Comer C-51
My husband and I have signed up to work but did not specify where because we weren't sure as this our first time working this event, we do not care where but would kind of like to work together if possible. Thanks so much.
I sure hope the entries pick up some in the next few days. With only 5 PDX and 22 TT entrants, it hardly seems worth a lot of people putting forth the effort to make this event happen
