2015 - Points #5 Results
    offset upper front control arm bushings will help with the static camber.
    -1.5 by just installing bushings.
    Not sure if they're legal for your class but I imagine they would be fine.
    Get your handling situated first then apply more power, if you need it.
    Lyle Cain's car handles great and he's fast even with a wore out 1.8L rattler.
      On 195 Toyo Proxes.
      Josh Bassett
      Black 1994 Miata
      CSP 49
        Originally posted by jbass1911 View Post
        On 195 Toyo Proxes.
        Old ones, at that.
          Originally posted by MX5_Racer View Post
          Actually I do think the 205/15's RE-71R's would be faster than the 225 RS3v2, but I've heard the Rival S is "as good as the RE-71R" and it is available in a 225/15, so that might be the better option.
          If you go XP, you can run real Hoosier's or at least some Hankook Z214's!!
          I don't consider myself an expert on suspension, but I have stayed at a Holiday Inn Express many times...and happy to share my thoughts/experience with you if you want. Good suspension and good tires will get the most out of your car, regardless of engine/power/class, so definitely recommend starting there.
          I would consider moving towards a slick if I jump into a different class and I would welcome your presence in my shotgun seat to get your opinion.
          Originally posted by rodhx View Post
          Tanner,
          You've got 9" wide wheels, right? If so the recent Grassroots Motorsports test showed the BFG Rival S in 225/45-15 on a 9" wheel to be essentially equal to the RE71R in 205/50-15 on a narrower rim (don't remember if it was 7.5" or 8").
          What engine are you planning to put in it?
          Acura J32A2 from a TL-S. Lightweight and similar rev range to the 1.8L. It shouldn't upset the balance of the car, but the necessary subframe change will lose me some dynamic camber gain. Eccentric upper arm bushings (see Mr. W8's comment) ought to gain some back by shortening the effective upper arm length.
          I really like these RS3v2's, but if I go through with the swap, my autocross tire setup will transition to slicks.
          My car's main purpose at this point is to teach me to be a better driver. This, in part, led to my choice to put a relatively small 3.2L v6 in. It will have as much power as a turbo setup, but it ought to run cooler and it will be quite easy for me to fix. It ought to be powerful enough to require precise throttle control, but it isn't so powerful that it won't be conducive to a momentum driving style.
          The car doesn't handle terribly and it doesn't have any real quirks. It responds as expected to driving inputs and setting changes. This is why I am pointing towards things like too little camber. If the springs are right, the damping is right, the sways are right, and the grip is balanced, then the camber must be fairly balanced front to rear. If there is simply not enough camber, then grip will be reduced.
          I would also like to point out that I will likely never be a Lyle Cain (or an Ayrton Senna while we are on the subject), but I still want to go fast.
          Tanner Powell
            Lyle Cain and Aryton Senna in the same sentence! You just made his day.
              I went through the XP rules again and it appears that my minimum weight with a 3.2L engine and an alternate subframe is 2024lbs. (1840+10% penalty) I don't know enough about XP as a national class, but that is not much weight.
              Tanner Powell
                Nope. You probably won't have any trouble getting to the minimum weight in XP for most modern cars.
