2011 Points 1 results
  • 2011 Points 1 results
    And points ...
    You have to be logged in.
    Dammit to hell yoder, a tenth!!!!!!!!!
      Dang..still not in the top ten. Maybe next time. C
        Now I wish I hadn't been doing so much drifting :P
          RESULTS UPDATED to show SM 42 and NASP 1. Part of the registration issues ... my mistake. Sorry.
            BTW, we had a couple of mis-classifications to look out for next time. The silver 350z, NBS1, should have been NCS. She said the trailer told her BS, but remember the entirety of BS merged with CS at the start of 2010, which means RX-8 and 350z is CS.
            Also, the green Porsche 944 has a 968 motor swap. I think he ran a novice stock class as well.
              Okay ... the NBS car went through a lot that day. She heard Echo instead of Bravo initially, and no one in the trailer knew it was really Charlie. I will make changes ...
              NBS1 > NCS1
              Porsche 944 to NSM? Or NSSM?
                what is tire pax? dumb question?
                Barry Hopper
                "We're gonna need a bigger garage!"
                  Tire is a PAX class for those drivers who want to run on street tires against other drivers on street tires, but don't want to run in the standard ST classes.
                  In ST, you are required to run on street tires and you compete against similar cars based on raw times.
                  In the Tire PAX class, you get a PAX modifier for your base class (CS, SM, etc) and you run against other drivers from any other class (aside from ST classes) who choose to run on street tires as well.
                  That's the biggest difference ... In "T" you can run a HS Mini against a SS Corvette against an SM Evo and compare the drivers ... not the car. In the defined ST classes you run only against similar cars in that class.
                    Thanks. Maybe I will learn all this stuff one day.
                    Barry Hopper
                      Just when you do, it'll change. Car classing is a moving target based on who did what to whom at the nationals the previous year. CSP may become DSP to make room for a new FSP which will displace the old FSP to somewhere else...
