why is it removed? was it a wreck or what?
Points Event #1
Red, come on out. If our ever lightening SE-R is legal then you should be too. Make sure the brakes are good, no chord on the tires and the battery is held down properly. Also need to have working seat belts as well.
Sweet i sure will and my buddie is coming to he drives a black s2000. Oh and as far as the seatbelts go i have harnesses bolted down so i should be good on that right..Originally posted by Jedi1 View PostRed, come on out. If our ever lightening SE-R is legal then you should be too. Make sure the brakes are good, no chord on the tires and the battery is held down properly. Also need to have working seat belts as well.
I don't think we have anyone in AS, what mods do you have, if you want some sort of cometition you could always run in XP with the SER
no sticky throttle, no air in brake lines, batt tie down, no loose lugs, no loose wires. And for clarification you can run a spare in the back, provided it is SECURE.
whoever is bringing the stuff please bring annual tech cards this time
Originally posted by Focus View PostWait how many people have red shoes? I just got my Piloti's in the mail yesterday. $36 shipped.
Wow that sounds like a deal? What style of Piloti's did you get?1988 911 :: #41 BSP
My 911 Road Trip Video :: Five Months With a Grrl and Her 911 :: 2009 Turbo Hot Lap@PSDS-Barber
Just a suggestion on that course design:
Back up the features you have on most of the crossroads so that they occur before the road, slowing down the cars early and letting them cross the berms at a slower rate, while accelerating, rather than braking or being unstable. That will save everyone some wear and tear on their cars and perhaps keep folks from looping as much.Eric Edwards
hideeho
the section of the lot where you have the start & finish has REALLY bad pavement. there is basicaly 1 line through it. we have been starting @ the hump before that (to the right in the picture) & finishing 1/2 way through that section, slightly closer to the bottom than the top.l8rcu
waflet (bill)
#42SM2 black turbo miata
hideeho
i signed up for setup, not design. i haven't put a thought into designing one. since you have, you're designer & i'm setup. i think sean will be out also. between us i'm sure we can get your course laid out.l8rcu
waflet (bill)
Holy isht balls batman. What are all those cones??? Time to get back into the "autocross has more that 20 cones on the entire course and is not like rallycross" mindset.
And FYI, I did the nasty today with my new pressure washer so as to not scare any of the newbies working the course when mud, dirt, gravel and the assorted not needed to run subaru parts fall off on course. Car lightening, the pressure washer way. w00t!!!!
