Great Idea, Three Laps Sounds Great Clay!
WORKER THREAD - Solo @ Dega 11/19/17
Originally posted by 94 R Package View PostGreat Idea, Three Laps Sounds Great Clay!.
Game on!Bill Clinton "It depends on what the meaning of the word 'is' is."
Yes, safety has concerns with going through the gate on the east side. Huge concerns. Plus the old road course, if I remember correctly is off camber and has uneven pavement. Even if we could do a course that long do we have enough people to cover it. Last I looked we have 30 registered.John W8
The actual pavement on the road course is fine except where they added uneven areas for the bike testing but it's off to one side. You can see it on the satellite image on the outside of the curve to the south. Really you could probably create a course just on the loop using features to avoid the uneven pavement...
The main area is small enough you really only need two or three worker stations and if we build the road course section with minimal cones it shouldn't take too many people.
And getting through the fence: What are the actual rules for that? As for getting through safely, just put a 90 degree turn to slow the car waaay down and then a straight shot. Would something like that work??Delanie Calhoun
'90 Spec Miata
'13 Ford Focus ST
2.2 COURSE SAFETY AND LAYOUT RULES
C. The course boundary shall not normally pass closer than 25 ft. from solid
objects.
2.3 COURSE DESIGN RULES
B. The course shall be at least 15 ft. wide and single-file slalom markers shall
be at least 45 ft. apart. Any series of three (3) or more course markers
which are generally in a line and have the effect of a slalom are considered
to be a slalom. Additional course markers associated with the slalom
markers to form gates, “boxes,” etc, do not cancel this limit.
The actual rules are pretty clear. Unless that gate opening is a minimum of 65' wide we can't go through it. (it's approx. 30') I know everyone want to have a larger site to run on but I won't approve a course that violates these rules and put us in a bind on getting further sanctions.
Who says 90 degree corners slow anyone down?Last edited by JohnW8; 11-09-2017, 04:22 PM.John W8
