reputible transmission shop
  • reputible transmission shop
    Anyone know of any? Carly's tiburon is having an issue in first gear and it's driving her crazy.
    Auto or manual?
      6spd manual..
      In first it randomly engages the clutch at different points of pedal travel and almost stalls the car.
        Does not sound like a transmission problem. Clutch master cylinder maybe? Slave cylinder? Have you checked the fluid?
          Yeah..Element Garage!..What did you do with the print out of the slave cylinder? Did you try whatever trick you read about?
          Remember folks dont believe everything you read on the web or forums for that matter.
            sounds like the slave cylinder or master could be leaking . Doesnt sound like a tranny problem . Drop by the Texaco if you like and Ill check it for ya .
              I haven't yet. Didn't really have the time to get in there.
              I'll double check the fluid and bleed the system just in case theres some air in there.
                No leaks anywhere, but the fluid looks disgusting (it's like liquid baby shit colored) and I haven't seen too much brake fluid in my life, but i've never seen it clouded like that.
                So I guess, in addition to taking that dumb valve/spring out of the slave cyl, I'll flush out the fluid and replace it with some new brake fluid.
                If it continues then I'll take it to someone to get a better diagnostic.
                  Hmmmm. Bring it around some time . Im curious .
                    So I tried the hyundai forum fix, and it seems like the previous owner already did that. So I flushed out the fluid and put new clean dot3 in there, still does it. It holds power up to redline, and at high rpm shifts, so I'm out of ideas.
                    Ricky, when's the next saturday that you work?
                      Ricky knows his stuff. He rebuilt an RX-7 tranny for me.
                      Brian Wilson
                      #27 CS MX-5 RF
                      In all forms of sport, competitors face challenges. In certain disciplines, there are physical barriers and psychological consequences. In racing, there are psychological barriers and physical consequences.
                        This is good to know.
                        Cholewa it really sounds like you clutch hydraulics are leaking. I've had slave cylinders leak into their boots and clutch master cylinders leak into the interior of the car. In both cases there are no external signs of leakage.
                          Well, I took the slave off the car to remove a spring/valve in it, and found it was previously removed. But it was clean as a whistle. I guess I could have a look at the master this weekend.
                            My next Saturday to work is next Saturday. 1/15/11
                              We will swing on by then.
