Anyone know of any? Carly's tiburon is having an issue in first gear and it's driving her crazy.
reputible transmission shop
Does not sound like a transmission problem. Clutch master cylinder maybe? Slave cylinder? Have you checked the fluid?
sounds like the slave cylinder or master could be leaking . Doesnt sound like a tranny problem . Drop by the Texaco if you like and Ill check it for ya .Ricky R
I haven't yet. Didn't really have the time to get in there.Originally posted by edtype1 View PostYeah..Element Garage!..What did you do with the print out of the slave cylinder? Did you try whatever trick you read about?
Remember folks dont believe everything you read on the web or forums for that matter.
I'll double check the fluid and bleed the system just in case theres some air in there.M. Cholewa
No leaks anywhere, but the fluid looks disgusting (it's like liquid baby shit colored) and I haven't seen too much brake fluid in my life, but i've never seen it clouded like that.
So I guess, in addition to taking that dumb valve/spring out of the slave cyl, I'll flush out the fluid and replace it with some new brake fluid.
If it continues then I'll take it to someone to get a better diagnostic.M. Cholewa
So I tried the hyundai forum fix, and it seems like the previous owner already did that. So I flushed out the fluid and put new clean dot3 in there, still does it. It holds power up to redline, and at high rpm shifts, so I'm out of ideas.
Ricky, when's the next saturday that you work?M. Cholewa
Ricky knows his stuff. He rebuilt an RX-7 tranny for me.Originally posted by zukitek View PostHmmmm. Bring it around some time . Im curious .Brian Wilson
#27 CS MX-5 RF
In all forms of sport, competitors face challenges. In certain disciplines, there are physical barriers and psychological consequences. In racing, there are psychological barriers and physical consequences.
This is good to know.Originally posted by WickedLoose View PostRicky knows his stuff. He rebuilt an RX-7 tranny for me.
Cholewa it really sounds like you clutch hydraulics are leaking. I've had slave cylinders leak into their boots and clutch master cylinders leak into the interior of the car. In both cases there are no external signs of leakage.Charles
Well, I took the slave off the car to remove a spring/valve in it, and found it was previously removed. But it was clean as a whistle. I guess I could have a look at the master this weekend.Originally posted by slowautoxr View PostThis is good to know.
Cholewa it really sounds like you clutch hydraulics are leaking. I've had slave cylinders leak into their boots and clutch master cylinders leak into the interior of the car. In both cases there are no external signs of leakage.M. Cholewa
