Setup Crew Sign Up Points#10 11/14/10
  • Setup Crew Sign Up Points#10 11/14/10
    Points #10 is coming up and that means the Annual Charity Event.
    The Bham Chapter of the American Association of Critical Care Nurses will be our guests and providing coffee and donuts for donations as well as running the fun runs for donations. There is some mention of Pizza being delivered with proceeds going toward the charity as well. Entry fee will be a flat $25.00 for all entrants and you'll get 3 timed runs for points then we'll crank up the fun run machine and all cash or goods donated will go to the Lovelady House. More info can be found at http://www.alscca.net/autocross_view and lovelady.homestead.com. It's a worthy cause, so let's dig deep today and help brighten someones tomorrow.
    Points #10 at Birmingham Race Course. Sunday November 14th, 2010
    Please post up here for positions on the setup crew.
    For those of you who want to be on the setup crew but have never done it, show up early and get a feel for what is needed. Help out where you can and learn from those who are there. These are your events, if you want them to be great, help to make them great.
    Early Set Up / 6:30a
    #1 Event Chair / John Waight
    #2 Course Designer / Eric Edwards
    #3 Set Up / Charlie Wagner
    #4 Set Up / Zac Hardiman
    #5 Set Up / Ben Hardiman
    Timing and scoring / 7:00a
    #1 Registrar/ Matt Williams
    #2 Cashier / Katie Williams
    Waiver station / 7:00a to drivers meeting is work assignment for the day.
    #1 Sean and Ron Ittner
    Tech Inspection / 7:30a
    #1 Casey Stallings
    #2
    Safety Stewards / 7:30a We need 2 minimum
    #1 Rod Hardiman
    #2
    #3
    Novice Directors / 8:00a
    #1 Jeremiah Hodgins
    #2 Mike Cholewa
    Early Setup
    John, I will help with the early set up. Charlie
    Charlie
    Black BMW Z4
      C and I will NOT be there, we will be in the beautiful country of Peru visiting family.
        I will also be absent .
          I will do setup and course design if Clay can't make it. Also Devotional.
          Eric Edwards
            I can cover a SSS unless someone else needs to get one in this year.
              I confirmed Zac & Ben are coming as well. We will be there early as usual, so Zac for early setup & Ben can cover early waivers if the Ittners are not attending.
              EDIT: I see that Sean & Ron are coming, so please move Ben to an early setup spot if help is still needed.
                I will be there to compete but I will be driving from Auburn that morning so I won't be able to make setup crew.
                - Jordan, GS-15
                  I can cover tech.
                    I will probably be out of town, but if I am here, I will help Eric with course setup.
                      I might need some help to make sure I cover everything, but I can help out with novice.
                        Hmm... nevermind I'm probably not going to be there this time. Very sad, but we have a neuro final on Monday. ARGH
                        - Jordan, GS-15
                          Ummmm... The event is on Sun, not Mon. j/k
                            Great! It's not hard at all. You have been to enough meetings that I'm sure you have it memorized. But I can send you a little check list if you want. Then all you have to do is get them all lined up on one side so if they want a ride, and you have to go ask each driver, then they can. Thanks for your help!
                              I'll help with whatever. Just put my name somewhere after 7:30.
