ok, so I got some new tires, but its got me wondering. Basically I have my stock wheels which are 17x6.5 and the stock size tire is 215/50/17. Now since the max size for ST class is 225mm, I got Star spec 225/45/17. I had nittos in the same size a while back and they were alright, I just had to lower the pressure. There was a slightly bigger bulge in the sidewall with the weight on it but I'm not sure if it was as wide as the dunlops. The tire is about 1/2-1" (just looking at it) wider than the stock tires. I just hope that the rolling in the turns won't put to much pressure on it at the events.
Just Curious
Just Curious
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.Tags: None
It's no big deal. Most of us Evo's run 255s on the stock wheels, which came with 235s. They might need a little more pressure, but that's all.
That 225/45 will give you a little better gearing too, so you'll probably like that.Matt W.
I've had my star specs for 6 months now and ran about 8 events plus daily driving and I can tell you...you'll love them. The tread pattern is wider (more squared than rounded edge) and slightly smaller stiffer sidewall with the new size you have compared to the old tires, which is most likely why your not seeing the "bulge" you described. The sidewalls of the Dunlops are rather stiff compared to many other street tires I've had in the past.
I also noticed less bulge coming off of Kumho ASTs in the same size myself.97 Civic HB - FSP Lucky#13
"Speed has never killed anyone, suddenly becoming stationary… that's what gets you." - Jeremy Clarkson
