John does this help you with that radiator problem?
ITEM 2) In Street Prepared, add a new subsection 15.10.I, regarding radiators, as follows:
“15.10.I Engine cooling radiators may be replaced with alternate parts subject to the following restrictions:
1) Radiator core dimensions (width, height, thickness) must be no smaller than the standard part.
2) Radiator must mount to OE radiator mounts.
3) Fluid capacity /_and dry weight_/ of radiator must be no less than that of the standard part.
Alternate radiators may serve no other purpose (e.g. to allow a cold air intake passage).”
FOr that matter the mini cooper in general is underclassed as a HS/GS car as ev idenced by Sean Yoder running 55-56 seconds in the last event when the average was 57-58
