Autocross alignment
  • #31
    I went with these settings ...
    Front:
    -2.7º and 0 toe
    Rear:
    -1.3º and 0 toe
    I checked the temps on Sunday and the fronts were 138º even across the board. Rears were 122º and even as well.
    I think I might be running a little too much pressure up front based on wear patterns, but otherwise I'm happy with the setup. I could probably get more grip up front with around -3.0º or more camber, but this seems to be a nice balance since I do drive the car every day.
    • #32
      Thats a good set up matt. I said that because I used the same lol. now..If ican just get me some tires...C
      • #33
        My setting on the e46 for N vs.S:
        Front Camber: L -2.5, R -2.5
        Front Caster: L 5.6, R 5.6
        Front Toe: 0
        Rear Camber: L -2.0, R -2.0
        Rear Toe: .28deg.
        Front tires 34psi cold
        Rear tires 38psi cold
