Musclecar Rallycross
  • Musclecar Rallycross
    While we're on the subject of "Will it Rallycross?" - I'm slowly getting a 1974 Dodge Charger I drove in the '90s back on the road and wanted to bring it out to RallyX.
    I can say with confidence its rollover risk is minimal (track width > height by a good deal).
    Power levels are actually not excessive - its 318 was rated at 265 ftlbs factory and if I have to rebuild it, I plan to build for about 300 ftlbs.
    Shipping weight is listed around 3500 pounds (basically, add a tank of gas to that to get curb weight). For comparison, a current Charger has a curb weight around 4200 pounds. It may be a larger risk for chewing up a course than a little Ranger, though.
    I don't expect it to be fast. I'm betting it would be fun, though.
    Joseph B.
    CS 82
    Ford fan that now has a garage full of red Mazdas.
    I'm going to contest every win you have!
      A sure-grip will go a long way in making sure you have fun.
        Quote for truth. I suspect the 2.71 ratio open diff it has now is less than optimal for pretty much everything except cruising at 65 mph.
        Joseph B.
        CS 82
          It'll still be fun at the dry events.
            I'd replace all the front suspension components before you go barreling down a field in 40 year old , 3800 lb car
            Rusty Spray
            '91 Camaro RS -- Sold
              That's good advice. Doesn't make sense to trust 40 year old rubber bushings.
              Joseph B.
              CS 82
                They had rubber back then?!
                (Like I'm one to talk ...)
                  I'd start with the ball joints and tie rods first, then go to the shocks and finally bushings.
                  Rusty Spray
