I just bought this and got it working and its pretty impressive http://www.msextra.com/forums/viewto...p?f=67&t=48208
works on the can network and can function as up to 12 differant guages with a push of a button on the front of the gauge. The lens is clear and I didnt like the CB being visible so I tinted the lens with some 5% window tint. It can display any parameter that MS sees so long as it can be displayed in 3 digits or less. RPM can be displayed x10. Ive had it configured and working for 3 days now and iM pretty happy with it . It works with all MS2Eand MS3 units including microsquirt based units using MS2e firmware. For $87 shipped its a fantastic piece. Say good bye to AFR guage/TS innacuracy. You see exactly what MS sees. If you have fuel pressure, oil pressure, boost pressure sensors piped in to MS then that is even more data you can get in one guage. I plan to probably buy at least 1 more of these if not 3. I highly recomend it
