What is the widest wheel you would want in the front. I know with the new car I can run 10.5 with 295 tires in the rear but would it be smart to square it up and run the same up front?
How wide is too wide
Tags: None
I'll post that once I pick up the car and can measure it.Originally posted by JohnW8 View PostHow much room do you have? I've heard you put all you can in the space provided. When you run out of room you buy fender flares and a sawz-all
What is this car? and what class?? Because that can limit your wheels n tires size, like for excample IF i were to run my STI in STU. I can only run 9" wide and 245 max. COriginally posted by SamC View PostI'll post that once I pick up the car and can measure it.Chaisit T aka C the gangster
Assuming everything works out this weekend...........2007 Nissan 350Z Enthusiast package, I'll be running BSPOriginally posted by c-evoVIII View PostWhat is this car? and what class?? Because that can limit your wheels n tires size, like for excample IF i were to run my STI in STU. I can only run 9" wide and 245 max. C
To ask my question more clearly, at what point is it no longer worth it. Money and performance wise. How much better are 10.5 vs 9.5? Is square better than staggered and to what degree is it better.
I would think square would always be better unless the cars handling/power characteristics dictate much wider in the back. Being able to rotate front to rear is a pretty big deal to me with A6s.
When your rotating mass negates the grip of the wider tires. Your best bet aside from testing is to look over results, see whos faster with what tire size, and check the weights of the different wheel/tire combos you want to run. The question is, which gets you more, weight savings (via smaller wheels/tires) for speed/accel or more grip from fatter tires.
And of course, what your budget allows.
I posed this question earlier and didn't get much of a response other than run what you can afford to run.M. Cholewa
