Just curious what everyone is using?
All of the fittings for my oil system parts are 3/8 NPT. They are all aftermarket as there are no external oil parts stock.
I've got -6 AN fittings for the fuel system already, and was planning on -8 AN for the oil system. But, I'm reading that the ID of 3/8 NPT is approximately the same as -6 AN. Is running -8 AN overkill, or would -6 be a bottleneck if I went with that from the 3/8 NPT adapters?
What do you guys use?
