I'm going back and forth on what to do for idle control for the Beetle.
I built the MS unit to control a PWM idle valve (Bosch European style ... BMW, Volve, VW, etc) but I really don't want to run the ridiculously huge lines those valves require. With the dual plenum setup I'd have to run 2 and deal with splitting the line and it became a bit more than I wanted to deal with.
I also considered using a small solenoid for a simply fast idle, but it really wouldn't make a huge difference. Maybe 200 RPM idle increase. Not really worth it.
I also considered a manual control from the dash. That's not going to save me any trouble really other than bypassing te ECU, which is already set up to run a valve.
Or, I could leave it without idle control and just hold the throttle for a couple of minutes on the occasions that I drive it.
What would you do? Is the extra plumbing worth it for a stable idle on cold starts?
