I'm looking into building a custom exhaust over the winter for my E30. This would be mainly to save weight but if I could free up the exhaust and gain some power that would be nice as well. The rules in STX say that a cat-con has to be run. I'm looking at doing long tube headers into a y-pipe and then a single pipe (instead of duals) to the back of the car. I'd probably go either 2.25" or 2.5" piping through a high flow cat and then into a magnaflow muffler. So my questions are:
Is there a preferred high flow cat?
Ceramic vs metal core?
Best for the cell count to be the lowest for maximum flow?
Are the magnaflow ones from jegs or summit just as good as others?
Edit: So I just found this place: http://www.mil-spec.org/2.5-100-Cell-Weld-In-Cat.html Seems to get good reviews, I assume this counts as a legal cat in SCCA?
I'm researching as much as possible but any advice or personal experience would be appreciated!
