suspension and gas mileage
  • suspension and gas mileage
    Well yeah. Lowering a car and reducing the airflow underneath reduces drag, thus reducing necessary energy to keep the car at a constant speed.
    You could obtain this same effect by cutting the springs...although even as a drifter I can't bring myself to ever own a vehicle with cut springs. They're just SO bad.
      I'm not buying 8%. Sounds like a job for Mythbusters to me.
      Cutting springs makes them shorter and increases the spring rate. I can see that this doesn't have to be a bad thing. To excess, surely it is.
        I call marketing BS (sorry if that is redundant). I don't doubt that there could be some benefit, but 8%? Both cars I have lowered have seen no mileage increase, and one was with a magical Eibach pro-kit. I keep very good mpg records and would have noticed any significant change.
          The data is there, but I'd like to see a 3rd test just to verify. To do this correctly, you'd want to take 3 data samples and use the median.
            There's a 10 degree temperature difference between the 2 tests. Maybe the VW ECU leaned it out a bit due to temperature.
            Correction 6 degree temperature difference.
            But still... 8%? C'mon!
              Dont forget though rod, when you lowered the car, you also probably put stickier tires on, and that does make a difference.
              With some eco tires on the rabbit, I was getting 33 on the highway (never seen over 28), and with the star specs I was getting 25.
                Nope...same street wheels and tires before and after on both the miata and the civic. No discernable change in mileage regardless of city, highway, or mixed driving.
                  Maybe you just need a german car
                    Got two already, but one is confused and thinks it is english
                      You clearly didn't lower it enough
                        Tire rub is not aero.
                          Yes, it seals the gap so air can no longer flow between the tire and inner fender, reducing turbulence
                            at the cost of how much friction? (forward momentum being turned into heat?)
                              Dude...I was kidding.
