Aurora Alternator problem
  • Aurora Alternator problem
    Ok, 97 olds aurora w/ 4.0 v8. I have replaced the alternator twice (1st was a bad part), and still no charge. The battery light comes on when the voltage drops below 11v. There is also a thermistor that increases alternator voltage when needed from lots of accesories running. I believe the thermistor is good but think the problem is in the connector (or to the connector). Any info is helpful.
    UPDATE: found some burnt wires behind exhaust manifold that lead to the connector and other things. Trying to back the wiring harness out now, o and spending time with the wife too since it is her bday
