To all of you guys running megasquirt 2 especially you that have had problems with AE false triggers, noisy TPS dot , and crappy idle control ....our prayers have been answered!!! I have about 100 miles on this new code and it is simply the bomb. I have been able to achieve a TPS dot threshold of 2.5 with absolutely 0 false triggers and my idle control is rock solid !! This beta test mod can be found http://www.msextra.com/forums/viewto...p?f=91&t=44289
Try it ...you wont be dissapointed ! If you are on firware older than 3.3.0 then you will likely have to remap VE as it will be about a point rich due to the map averaging code that was added in 3.3.0 but you wont be disappointed in the results.
