Coil Spring Compressors?
  • Coil Spring Compressors?
    I need to remove the springs on the Evo and rented a coil spring compressor from Advance. It's not the kind I've used before. It looks like this one ... http://www.sears.com/shc/s/p_10153_1...1791000P?mv=rr
    Can this style be used on McPhearson struts or do I need to just buy a set that goes on either side of the spring?
    I've got a set of spring compressors that are the separate style. you can borrow if you need them.
      I do! Sadly, not going to be down that way this evening ... I need to get these things off and shipped to have it ready for the 10th. I might just run by and get them if I get the struts off this evening.
        try Autozone, some rent the type you are looking for
        Ford Escort #717 rallycross
        Bmw e21 #17 track car
          not sure how yours is set up but if you take the top nut off the strut with the car on jackstands and lower the lca's with a jack slowly you can do it that way. hope this helps
            Matt, take a look at this DIY vid, it's specific to a Miata but the concept is the same that Mike mentioned, no compressor needed:
            Andy Tow
            ND Miata
            Eliminator V2 - Sold-
              I've used that method before, but don't prefer it. Plus, the car is in the air with a bolt missing from the LCAs already. I went back to Advance and rented the correct tool. They just gave me the wrong one. I questioned it when I rented the first ones, but whatever. Now I know. Got one strut disassembled yesterday and will finish the rest this afternoon.
