I finally got my issues with my microsquirt module worked out (it was faultyand had to be replaced)and the car runs and I have got it tuned well enough to drive around . Got a couple things I havent been able to tune out .
1)The dash tach is not functioning correctly. It works at low engine speeds (innacurately) and drops out to 0 at higher RPMs mostly under high acceleration pulls.
2)started kickback during startup but I didnt have a timing light at home when I was setting everything up so that might just be a matter of verifying that I have the correct trigger offset in the tune . Its presently at 108 degrees. The cranking advance is set at 0 degrees.
