Help...
The wife has a 1991 Miata. I took it out for a test drive today after she complained about lack of power and sure enough, it will not go above 4000 RPM. Foot to the floor and it stops accelerating when it gets to 4 grand, any gear, and I also note some pinging/detonation. The only way to get it up to a highway speed it time and shifting before you get to 4000 RPM. Once you get there, it will stay there, unless you come to a hill...then it slows down and you end up having to downshift.
Could it be that crank pulley issue? I am going to look at it some more in a little while, but thought I would send this out to the 100's of miata owners out there...
As always, any help is appreciated. I will post more if I find anything else...
