Miata crank tool
  • Miata crank tool
    I will soon be attempting my first timing belt/water pump/seal job on the Miata. I see the ebay tools to help remove the crank bolt on the 1.6 but nothing for the 1.8, and I don't expect to be able to fab one myself. Any advice would be appreciated!!
    Rod i just burn't the 2 holes in a lawnmower blade, and as the car is on jackstands, slide a concrete block under the car to stop the blade. Cheap, easy, redneck engineering.
      Rod, I made one you can borrow. Works on 1.6 or 1.8
      Lemmeknow
