I've got some bad shaft play going on, and need a new turbo. Standard 4 bolt to the manifold flat flange t3 with a 3 bolt dowpipe. Oil only.
The stock volvo is a .57/.42 I believe, so anything in that range will be fine, 48-63 is all good.
