Karmann Ghia Flip
"Holy carp" is right, Nick!
That's pretty much exactly how I heard C describe it ... but I still don't really understand. I guess it being rear engined drastically changes the physics of that particular situation.Delanie Calhoun
'90 Spec Miata
'13 Ford Focus ST
The swing axles didn't help (see "Unsafe at any Speed," Ralph Nader.) Neither did the fact that, after he realized he was headed off at 13, he tried to steer more to the right. If he hadn't flipped, it would've been head-on into the fence drivers' right, unless somebody t-boned him on the way there. Variations on that scenario probably happen at least once every 4 weekends that cars run out there, at either turn 4, 11, or 13.
There's lots of green space in each of these places, despite what it looks like from the car, to safely track out wide, if you don't do anything sudden, or forget to straighten the wheel, which appears to be the case, here.Chuck Schultz
Well dern... shoot. That's that Porsche business lifting the front inside tire. Engine's in the wrong place. Another reason I want a 4 point cage minimum before I push my car on a track. Roof to center console real fast.Heath Patterson
Originally posted by chuck schultz View PostThe swing axles didn't help (see "Unsafe at any Speed," Ralph Nader.)Matt W.
Originally posted by TouringBubble View PostWas it a swing axle car?
From what I see in Wikipedia, it looks like the axle change on the Beetle took place in '67. It seems likely that the Ghia changed at the same time. The taillights on the video look a lot like the early Ghias, but those taillights could also be as recent as '69.
I finally looked at the registration list, and the car's listed as a '69, so you are probably right. There's so much compliance in the suspension, though, that it almost looks like a swing axle.
Thanks for the re-education.Chuck Schultz
Originally posted by chuck schultz View PostThanks for the re-education.
Either way, The VWs never had great suspension. Most owners don't care. This is specifically shown in the case of the Super Beetle which received McPhearson struts up front and a rack and pinion steering setup, both notable improvements. Most "VW guys" don't care much for them. I'm sure they are much harder to lower and maybe don't share the proper bolt pattern with the Porsche, which is the primary concern of too many owners these days.Matt W.
