The long day...
  • The long day...
    13 hours, 900 miles driven, 30 gallons of gas, two crappy breakfasts, two great shrimp baskets, two cups of coffee, two cheese danishes and a great day with my dad. Oh yeah, we did pick up a car as well.
    I hope it's either the PT cruiser in the background or the flamed out drop top Z.
      This sounds like someone that is sick of getting there butt kicked by a chick car...
        I'm sick of getting my butt kicked by chick cars on courses designed for chick cars.
          Where were you at the first 4 events? The 4wd guys did everything they could to kick the sissy cars in the teeth. High speed didn't work, tight didn't work, technical (if you want to call it that) didn't work... You need to set up the next course that way you can have the privilege of getting your butt kicked on your very own course
            Girls... please! When last I looked, VW's and Miata don't compete against one another in any class. Well, unless you're looking at raw times or pax then it doesn't look so good either.
              ouch
              fwiw: pax + miatas and vw's
              4m CSP 2 2 Mark McWilliams 94 Mazda Miata 39.139 *0.862 33.737 0.165 0.578
              5m CSP 6 6 Lyle Cain 1994 Mazda Miata 39.156 *0.862 33.752 0.015 0.593
              6m HS 17 17 Michael Cholewa VW Rabbit 42.242 *0.802 33.878 0.126 0.719
              7m CSP 63 63 Darryl Engle Mazda Miata 39.380 *0.862 33.945 0.067 0.786
              8m CSP 10 10 John Waight Mazda Miata 39.718 *0.862 34.236 0.291
              AXWare Systems (AXWARE_TS) - Autocrossing and Time-trial Solutions. Licensed to:Alabama Region of the SCCA
              punk ass
                PAX? your kidding right? You were beat by a chick car just like I said you were. Actually several of them and that cheater Clay.
                  considering the difference between your modified miata and my stock rabbit.. I think pax is reasonable.
                    Maybe so but your still getting beat by the chick cars just like I said you were even with PAX.
                      I'm not arguing that miatas are better than rabbits. I'm arguing that getting beat by a modified car in a stock car (truly stock) based on raw times is silly.
                          I thought you were implying that Miatas get special advantages in course design. The PAX numbers say you are more than capable of beating a Miata. Hat's off to you but to imply the course are designed for chic..err Miatas is plainly silly.
                            I'm not gonna say that courses are designed specifically for Miatas, but I'll say that the little buggers fit more easily through the gates on many courses.
                              There's no argument there. A small car will fit through a gate of given size better than a larger car. Honestly though the Miata isn't that much smaller (narrower) than a VW or an EVO. Heck my E30 is slightly narrower than my Miata until I put on the 255's then the E30
                              is a lot narrower.
                              VW GTI Width:69.3"
                              Track:60.4"
                              Mazda MX5 Width: 67.7"
                              Track:58.7
                              Is 1.6" really that much of an advantage through a 12' gate?
