I kinda like it. Wasn't this what Kilgore was going to do with his miata?
Yes!
Yes!
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.Tags: None
Yep. pretty much the plan. Except that there will be something a little more in the front around what would be the bumper area, and there will be something similar to fenders on the back (mainly cause i don't want to get slapped in the head with rocks coming off of 275 or 315 rear slicks). And less windshield frame, well, make that NO windshield frame.John Kilgore...if winning was easy, losers would do it.
Beast.
Check out this E30 putting a 458 away
Heath Patterson
Add door bars and be done with it. Wait... Add door bars and aircraft grade wings front and rear and be done with it. Wait... Door bars, HUGE wings and LMP1 size tires at all four corners and be done with it. WAIT....
you're getting close.Originally posted by Jedi1 View PostAdd door bars and be done with it. Wait... Add door bars and aircraft grade wings front and rear and be done with it. Wait... Door bars, HUGE wings and LMP1 size tires at all four corners and be done with it. WAIT....John Kilgore...if winning was easy, losers would do it.
