Wheel help!
  • Wheel help!
    Does anyone have any idea where i can find some 5 lug Mazda wheels for sale?
    Griffin Burkett
    Silver 07 Civic with yellow wheels brighter than the sun.
    SMF 15
    MX6 wheel pattern is a 5x114.3
    Do you have to run Mazda wheels?
    Mark K
      They need to be as small as mazda wheels. Like 14" or 15" wheels
      Griffin Burkett
      SMF 15
        5x114.3 is the JDM wheel of choice (NISSAN, and just about every other tuner car). Go to the pull a part on wed, half off. Wheels are normally what, 25 a piece?
          at pull a part they take the wheels off, weld them together and use them as jackstands
          Griffin Burkett
          SMF 15
            They take off the aluminum wheels and sell them individually.
              Griffin, when you say that, what exactly do you mean? Mazda makes wheels in sizes of all sorts....I think the Miata even came with 17" wheels in some forms.
              1. Are you specifically looking for a true Mazda wheel?
              2. Are you in need of a 14" or 15" wheel for a specific task, rally or autocross? I ask because you would definitely want to run a different type of wheel all together for rally vs. autocross.
              3. You could get a Ford or Chrysler 5x114.3/4.5 (which is the same thing; you know that right?) or just search for 5x4.5 instead or 114.3 because the domestic models will not be in the metric version.
              4. Also, what width are you looking for? In a rally wheel you would want a smaller width vs. an autocross wheel width. (say 14x5.5 or 6 vs. a CSP size wheel 13x9 or 15x10)
              Just some pointers and things to think about.
              John
                try these on for size?
                  I know where there are some bright yellow painted steelies that ought to fit
                    will 14's fit over the brakes?
                      I was thinking on using the my civic steelies, but someone said they might not work.
                      Griffin Burkett
                      SMF 15
                        14" are stock
                        Griffin Burkett
                        SMF 15
                          take 5 min and see.
                            95'ish mazda millinia wheels are nice and light. 15x6". Lots of the Integra type R guys run them for autocross.
                            99' red(ish) HS Integra
                            Wiregrass region
