OK to preface . I upgraded my brakes on my 240 a couple years back to Infinity J30 calipers and rotors .This meant that the parking brake totally changed from being applied through the caliper to the inside of the rotor hat with a drum type brake. I didnt rig the park brake at the time due to not having all of the stuff nor the time to mess with it . In other words it wasnt a priority to have the park brake .
Recently I found myself with time and parts and motivation so I proceeded to finish the park brake. Due to the fact that the park brake cable housings mounted further back in the car than the stock cables ...this meant I would need to anchor them anew..
This is where it gets funny. The S14 chassis uses a saddle gas tank that is totally covered by a sheet metal shroud that appears a lot like a floorpan. Guess where the first hole I drilled went .
Moral of the story is ...well I think you get it .
