ALSCCA Pts 4 Autocross 2025 Thread!
  • ALSCCA Pts 4 Autocross 2025 Thread!
    ALSCCA Pts 4 Solo Event's registration is live now!
    This event will be on Saturday (***5/17/2025 Rescheduled***) and is brought to you by:
    Click image for larger version  Name:	Corsa Crew Ad 1.jpg Views:	65 Size:	95.8 KB ID:	87401
    Registration:
    SCCA - Alabama Region on Saturday, May 17, 2025 at Barber Motorsports Park, Birmingham, AL - This event takes place on May 10th (*** Rescheduled to May 17th***) 2025! This event is a SEDiv Solo Series event, which means this event's results will be calculated for your series championship stan...
    This is a SEDiv championship series event! This means this event's results will be calculated towards the divisional points. Registration may see people piling in from neighboring regions, so be sure to register soon if you'd like to make it into the event!
    Course Map:
    Click image for larger version  Name:	Course Map.jpg Views:	0 Size:	34.3 KB ID:	87406
    Worker Signup:
    1. Event Chair: Nick Lindsay
    1A. Event Co-Chair: Johnny Brewster
    2. Course Designer: Nick Lindsay
    Friday/Saturday 3pmish - Course setup, time to be determined, likely mid-afternoon Friday. I will update once confirmed with Barber. You'll also be needed Saturday afternoon to make any adjustments between the test n tune and the Pts 1 Competition course. If I'm confident the changes will be small, you may be relieved on Friday.
    3. Course Setup 1: Mitch Vaughn
    4. Course Setup 2: Thomas Mitchell
    5. Course Setup 3: Edward Mitchell
    6. Course Setup 4: Del Williams
    7. Course Setup 5: Adam Johnson
    - - -Add'l Support:
    Sunday:
    8. Early Waiver & Checkin 1: Carvel Webb
    - - Early Waiver & Checkin 2: Carville Webb
    - - Early Waiver & Checkin 3:
    - - - Trailer and Computer Setup Shadow and Support: Edward Mitchell
    10. Early Paddock Marshalls: Haley Richardson
    11. Safety Steward 1: Glenn Stephenson
    12. Safety Steward 2: Brad Clarke
    - - - -SSS Shadow:
    13. Tech Inspector 1: Joshua Abts
    - - - Tech Inspector 2: Connor Lynch
    - - - Tech Inspector 3:
    16. Worker Chief:
    Report to Work by 7:45 AM
    - - - Intermediate Coach 1: Edward Fisher
    16. Novice Coach 1: Clay McCool
    17. Late Waiver & Checkin 1:
    18. Late Paddock Marshal: Justin Richardson
    NEW!
    Report to Work by ~ 4:30 PM (End of the event.)
    (Picking up all the cones on course and getting the truck stacked appropiately, and hooked up to the trailer. Also transport the truck and trailer to lot G)
    19. Truck Cleanup Lead 1: David Scott
    20. Course Cleanup 2:
    21. Course Cleanup 3:
    1.
    2.
    1. Edward Mitchell to Shadow Trailer and Timing Setup
    2.
    Hey nick could you put me down for tech
      Yes.
      Do we still have annual tech stickers, and will we need to get more "dot" stickers for tech?
      We will also like to set the scales up and make them available during the tech period of this event.
        Early waiver, please
        Eli Burchell
        1994 Mazda Miata STR 33
        2017 Honda Accord V6 6MT STX 33
        https://www.instagram.com/205.ct2/
          I would like to do novice or intermediate coach plz.
            We have plenty of stickers still and that’s fine either the scales
              Carvel for early waiver 1
              Carville for early waiver 2
                You can put Tom and I down for early set up.
                  Hey, y'all.
                  I had to reschedule the event to May 17th. If you can't make the work assignment you have already requested, please let me know. If the new date doesn't change anything for you I'm going to assume you can still work the requested assignment.
                    Unable to attend due to date change
                    Eli Burchell
                      IM coach
                        So i can help with COURSE CLEANUP end of event
                          Nick, Tom and I can still both do early set-up, and then I would like to shadow the timing set-up.
                            Haley has requested early paddock marshal.
                            You can put me wherever you want to. If no one else has a desire to do SSS I’ll cover 1 position.
                              Can do SSS. If the other is more local so I don't have to be there at 7am that would be great
                              Brad Clarke
                              Something Something Miata
