Pts 9 and 10 Double Header Supplementals
  • Pts 9 and 10 Double Header Supplementals
    This is a preview of the supplementals for Pts 9 and 10 this weekend.
    I wanted to go ahead and post them here to give folks plenty of time to look into them before the event.
    Supplementals:
    Hey, everyone!
    Thanks for registering for ALSCCA Pts 9 & 10 Solo (Autocross) event(s) for tomorrow (11/16/2024 & 11/17/2024)!
    This email will provide most of what you will need to know for this weekend!
    First time to one of our events and not sure what to expect? Check out our forum post below:
    Going to your first Autocross? Read me!
    Our schedule can be subject to change at the event, but this is the outline:
    Saturday SCHEDULE
    7:00 AM - Gates Open
    7:00 to 8:45 – Tech
    (Please have your items removed from your car and helmet with you so you can receive tech. Annual tech will be available for those who are interested. Be sure to ask. Tech WILL CLOSE at 8:45am. You’ll want to make sure you get your car tech’d ASAP when you arrive.) If your car is not tech’d it will not be allowed to compete.
    7:00 to 8:15 - Check-in / Registration (complete at Waivers)
    7:15 to 8:30 - Course open for walking (no new walks after 8:20)
    NEW! 7:45 Intermediate Walk – Optional to the more seasoned competitors who are looking to improve
    8:00 - Novice Walk - Mandatory for first (two) events
    8:30 - Mandatory Driver’s Meeting for all participants
    8:45 - Workers to stations, Competitors to grid
    9:01 - First car off
    ~12pm 1 Hour Lunch Break
    ~4:00 - Course clean-up and trophy presentation
    Sunday SCHEDULE
    7:00 to 8:45 – Tech
    ~11am 1 Hour Lunch Break
    (QUIET HOUR. THIS WILL BE AN UNCONDITIONAL STOP AT 11am. Any runs not made in the morning will be made up AFTER quiet hour!)
    Let’s try to be punctual so we can start on time and possibly get some fun runs!
    Supplemental Maps (See attached file)
    Run Groups
    (TBA Friday evening)
    Work Assignments
    Per the map, be sure to stop at the credentials building to fill out the appropriate waivers and receive a wristband!
    Trucks and trailers should park at the top across from the “usual spot” as outlined in the supplemental maps. This is to the right side of the road when you approach the upper level.
    Although overnight camping won’t be allowed for this weekend, leaving your trailers and cars on site is permitted. The park’s main gates will be locked after hours; so if you take advantage of this, make sure to get any belongings you’ll need thru the evening. (GoPro, GPS, truck keys, hotel key cards, etc.)
    The paddock space for participants who won’t have a truck and trailer will be the spots CLOSEST to the skid pad area in which we will be driving. THIS IS OUTLINED IN THE MAPS.
    If you are not in the first heat, please un-trailer your car or place your car near the road so tech can come by and inspect the vehicle. PLEASE MAKE SURE YOU HAVE YOUR CAR NUMBERS/LETTERS VISIBLE AS TECH WILL BE CHECKING TO MAKE SURE YOU’RE MATCHING THE REGISTRATION.
    The skid pad will only be available for heat 1 cars ONLY in the morning to park. We will switch out the run groups in grid at the appropriate time for heat 2 cars.
    Absolutely NO JACKS ON THE SKID PAD! We want to take the highest level of care of the skid pad area that we will be gridded on.If you are seen using a jack or jack stand on the skid pad you may be asked to leave! If you need to use a jack, please do so on the other paved surfaces or in the grass.
    Note your car class and number on the run groups page! Please ensure that you are prepared to put your class and number on the side of your car. These will need to be visibly placed in a fashion your car can be identified in grid, at the start line, and on course. These need to be VISIBLE. You can use painters tape, duct tape, or magnets. If you use a piece of paper with your cars identification, please make sure that it has a BOLD font that can be easily distinguished from a distance. This may require multiple pieces of paper to facilitate. The target size is letters and numbers that are ~ 8” tall on the SIDES of your car. I won’t be walking around with a tape measure, however the better of a job you do with this, the better the event flow will be with less confusion for timing and scoring which could net in MORE RUNS!
    Be weather aware and you should plan accordingly and bring what you think you may need for the conditions. The club will have some waters available. We will run rain or shine!
    You will be expected to work for the opposite heat that you are driving in! The only exception for this is people who have been early workers. If you leave early without working your assignment this will result in you being blacklisted from our events. I’m not unreasonable about emergencies and things of that nature but please do not abuse the fantastic people of this sport!
    If you need any accommodations with your work assignment that you've been requested to work, see the worker chief in the morning and we can make some adjustments.
    If you are unsure of your work assignment or your work assignment/run group was not listed in the attached PDF see the worker chief in the morning and we can get you squared away.
    IF you were wait listed and added to the event, please be sure to follow up with the timing trailer to make sure you're in our timing system for the event.
    Loaner helmets will be available but these are limited so be sure to place them back at the end of your heat so others can also borrow the helmets. Please use the head socks!
    If there are any questions, feel free to respond to this email and I will try to get back with you in the morning. If I fail to do so, just come find somebody in the paddock first thing and we can get you pointed in the right direction.
    Thanks for coming and safe travels everyone!
    Update:
    Grid Layout Uploaded 11/13. (Attached below) Please be sure to understand the traffic flow of the grid area.
    Thanks for posting!
    I have an FSAE car, and I don't think I've driven down that ramp before. Is it suitable for low ground clearance cars?
    Looking forward to the weekend
      Originally posted by CPMaverick View Post
      Thanks for posting!
      Yes, I believe it is just fine.
        Nick, I’m not seeing myself or my son Sam listed in the documents or work assignments. Please contact me and let me know if I’m just not looking in the right place. It may be that the links are directing me to older race documents.
          Those were outdated group pages that I didn't mean to string onto this forum post. I've disabled those files from the post now.
          I will email out all the run group information on Friday evening.
