ALSCCA Pts 5 Worker and Map Thread
  • ALSCCA Pts 5 Worker and Map Thread
    ALSCCA Pts 5 Autocross! 6/22/2024
    Registration:
    https://www.motorsportreg.com/events...alabama-164100
    Course Map!
    Click image for larger version  Name:	Bowling Ally.JPG Views:	0 Size:	35.7 KB ID:	87103
    1. Event Chair: Nick Lindsay
    2. Course Designer: Nick Lindsay
    Friday - Course setup, time to be determined, likely mid-afternoon. I will update once confirmed with Barber.
    3. Course Setup 1: Adam Johnson
    4. Course Setup 2: Mitch Vaughn
    5. Course Setup 3: Charles Wolford
    6. Course Setup 4: Jacob Cicero
    7. Course Setup 5: Drew Cicero
    - - -Add'l Support:
    Saturday
    8. Early Waiver & Checkin 1: Lyle Cain
    - - Early Waiver & Checkin 2:
    - - Early Waiver & Checkin 3:
    - - - Trailer and Computer Setup Shadow and Support:
    10. Early Paddock Marshalls: Christian Holly
    12. Safety Steward 2: Johnny Brewster
    - - - -SSS Shadow: Connor Johnson
    13. Tech Inspector 1: Connor Lynch
    - - - Tech Inspector 2: Joshua Abts
    - - - Tech Inspector 3:
    16. Worker Chief:
    16. Novice Coach 1:
    - - - Novice Coach 2:
    17. Late Waiver & Checkin 1: Eli Burchell
    18. Late Paddock Marshal: Haley Holly
    1. Ken Nevins
    2.
    1.
    2.
    Hey Nick, you can put me down for tech again.
      Could you also put me down for tech
        I can do SSS if no one else is willing. I can also do early paddock marshal. Also willing to work start or grid. I think as for now Haley wants to continue with course work.
          Could you put me down for Course Setup? - Adam Johnson
            Thanks for link to forum.
            i will be novice and will show early for 6:45 and see if I can find my place to assist where I can.i do have some limitations .
              If setup is the day before, I may be able to assist then. Do you contact directly with email with details?
                I’ll do SSS as well or Paddock Marshall.
                Johnny (Jay)
                  SSS Shadow please!
                    Course setup
                      Yes, I usually contact folks the evening before the event with an arrival time and other details. Setup will be Friday at 3pm so you can plan around that.
                        Weird question - are popups allowed? In the mid 2000's popup tents were available. I have a 12x12 I could bring and set up at a corner, but I don't know if that would cause problems if there's only one.
                          Can I get on course setup again? Thanks
                            The club still has some "easy ups" in the truck, although they will likely be soon replaced when the club acquires a new trailer at the end of the season.
                            The "easy ups" are rarely easy down, unless of course there is much wind. In that case they are a kite waiting to take off!
                            I've found it most effective if you can bring a large umbrella with you for shade. If you're working a corner and have to reset a cone, the umbrella can be easily sat down and retreived after resetting the cone. The umbrella I got at Walmart has been awesome for working course and it has a carbon fiber rod to boot! It was like $14
                              Tech 3, Early waiver 2, Novice Coach [shadow], or surprise me
                              Eli Burchell
                              1994 Mazda Miata STR 33
                              2017 Honda Accord V6 6MT STX 33
                              https://www.instagram.com/205.ct2/
