ALSCCA Pts 4 Worker & Map Thread
  • ALSCCA Pts 4 Worker & Map Thread
    ALSCCA Pts 4 Autocross! 5/25/2024
    Registration:
    https://www.motorsportreg.com/events...alabama-290071
    Course Map!
    This first map is the intended course design. In the event of extremely wet conditions, or other unforeseen circumstances, the course may be altered.
    ***Map Updated on 5/23/23***
    1. Event Chair: Nick Lindsay
    2. Course Designer: Nick Lindsay
    Friday - Course setup, time to be determined, likely mid-afternoon. I will update once confirmed with Barber.
    3. Course Setup 1: Nate McCrary
    4. Course Setup 2: Mitch Vaughn
    5. Course Setup 3: Rachel Hart
    6. Course Setup 4: Drew Cicero
    7. Course Setup 5: Rahul Thadani
    - - -Add'l Support:
    Saturday
    8. Early Waiver & Checkin 1: Lyle Cain
    - - Early Waiver & Checkin 2:
    - - Early Waiver & Checkin 3:
    - - - Trailer and Computer Setup Shadow and Support:
    10. Early Paddock Marshalls: Christian Holly & Hayley Holly
    11. Safety Steward 1: Jim Farris
    12. Safety Steward 2: Johnny Brewster
    - - - -SSS Shadow: James Mitchell and Connor Johnson
    13. Tech Inspector 1: Joshua Abts
    - - - Tech Inspector 2: Connor Lynch
    - - - Tech Inspector 3:
    16. Worker Chief: Justin Richardson
    16. Novice Coach 1: Andy Williams
    - - - Novice Coach 2:
    17. Late Waiver & Checkin 1: B-Rad Mintun
    18. Late Paddock Marshal:
    1. Ashley Lindsey
    2.
    1. James Mitchell shadow SSS
    2. Connor Johnson shadow SSS
    I would like to be early waivers if possible. Thanks
      Could I be put down for tech
        sss shadow if possible.
          Hey Nick, I'll do tech again.
            Can I get on course setup?
              If you need an early worker, I've decided to show my face again
              www.alsoranracing.com
                Course setup on Friday good?
                Late waiver is also available.
                  Work won't allow me to do Fridays. I can help with waivers or just shag cones... whatever you need.
                    Put me down for Novice Coach or Paddock Marshall as needed!
                      Nate McCrary for early waiver or additional course setup if its available/needed, thanks
                        Updated
                          I noticed that there is only one timing person assigned. I know how to run Axware and do it in Huntsville, if you guys need help with timing, Id like to learn and help with the Pronto stuff. I talked to Brett last weekend about it and he mentioned that it might be good if I could help out since Im at all the events. Just let me know, always glad to help where needed!
                            Thanks, Ken.
                            We will definitely take you up on that offer! Pronto Timing is pretty easy, and more importantly, more reliable than Axware in our uses. You'll pick it up quick, no doubt.
