ALSCCA Solo Pts 2 2023
  • ALSCCA Solo Pts 2 2023
    Registration is available at the link below:
    https://www.motorsportreg.com/events...alabama-013908
    Course map ADDED IN THE COMMENTS BELOW!
    If you are interested in designing a course, reach out, or submit your ideas to: alscca.solochair@gmail.com
    Early Worker Signup Thread Pts 2 - Saturday March 25th 2023
    1. Event Chair: Nick Lindsay
    2. Course Designer: Justin Richardson
    Friday - Course setup, time to be determined, likely mid-afternoon. I will update once confirmed with Barber.
    3. Course Setup 1: Nick Lindsay
    4. Course Setup 2: Steve Saunders
    5. Course Setup 3: Jim Farris
    6. Course Setup 4:
    7. Course Setup 5:
    - - -Add'l Support:
    Saturday
    8. Early Waiver & Checkin 1: Keith Smith
    - - Early Waiver & Checkin 2:
    - - Early Waiver & Checkin 3:
    - - - Trailer and Computer Setup Shadow and Support: Johnny Brewster
    10. Early Paddock Marshalls: Alicia Harrington
    12. Safety Steward 2: Glenn Stephenson
    - - - -SSS Shadow:
    13. Tech Inspector 1: Eli Burchell
    - - - Tech Inspector 2: Jerami Bailey
    - - - Tech Inspector 3: Tom Harrington
    16. Worker Chief: Brad Mintun
    16. Novice Coach 1: Andy Williams
    - - - Novice Coach 2: Jim Farris
    17. Late Waiver & Checkin 1:
    18. Late Paddock Marshal: Kameron Neal
    1. Dwayne Custer
    2. Joshua Toxey
    1. Johnny Brewster to shadow Timing
    2.
    Hey Nick...I'll shadow timing.
      I'd like to do tech inspections. Haven't done it and would need some instruction on expectations. If I could shadow someone that would be great.
      if not tech I could do early waivers
      Jerami Bailey
      Xsm 13
      Jerami Bailey
      😓2013 white BRZ😓
      2013 Smurf blue frs
        I can show the young whippersnapper what tech's all about.
        Eli Burchell
        1994 Mazda Miata STR 33
        2017 Honda Accord V6 6MT STX 33
        https://www.instagram.com/205.ct2/
          I can do early paddock marshal if you have others that want or need to do some SSS work. If not I’ll stay where you have me at.
            This is a good point. If somebody else is a SSS, you need to make sure you have enough events to keep it current. Please reach out if you need help in this regard. We want to keep SSS flexible.
              You can sign me up for whatever you need, early or otherwise.
              www.alsoranracing.com
                Click image for larger version  Name:	Pts 2 Course Map.JPG Views:	0 Size:	44.2 KB ID:	86718
                Take note of the "crossover."
                Thanks to Justin Richardson for the design. This should be a great course!
