ALSCCA Solo Pts 1 2023
  • ALSCCA Solo Pts 1 2023
    It's finally here, the start to the 2023 season!
    ***Course map in the comments***
    Registration is available at the link below:
    https://www.motorsportreg.com/events...alabama-946667
    A course has not been selected YET. (Course map has since been added.)
    If you are interested in designing a course, reach out, or submit your ideas to: alscca.solochair@gmail.com
    Early Worker Signup Thread Pts 1 - Saturday February 25th 2023
    1. Event Chair: Nick Lindsay
    2. Course Designer: Nick Lindsay
    Friday - Course setup, time to be determined, likely mid-afternoon. I will update once confirmed with Barber.
    3. Course Setup 1: Nick Lindsay
    4. Course Setup 2: Eric Grzelakeric
    5. Course Setup 3: Parker Grzelakeric
    6. Course Setup 4: Jim Farris
    7. Course Setup 5: Steve Saunders
    - - -Add'l Support:
    Saturday
    8. Early Waiver & Checkin 1: Jerami Bailey
    - - Early Waiver & Checkin 2: Byron Robbins
    - - Early Waiver & Checkin 3:
    - - - Trailer and Computer Setup Shadow and Support: Johnny Brewster
    10. Early Paddock Marshalls: Rod Hardiman
    12. Safety Steward 2: Steve Saunders
    - - - -SSS Shadow:
    13. Tech Inspector 1: Tom Harrington
    - - - Tech Inspector 2: Eli Burchell
    - - - Tech Inspector 3: Zac Hardiman
    16. Worker Chief:
    16. Novice Coach 1: Andy Williams
    - - - Novice Coach 2: Ed Fisher
    ****Novice Coach 3**** Jim Farris (We may need this third position with the number of registered novices.)
    17. Late Waiver & Checkin 1:
    18. Late Paddock Marshal: Alan Kim
    1. Dwayne Custer
    2. Joshua Toxey
    1. Keith Smith to shadow Timing.
    2. Johnny Brewster to shadow Timing
    I would like to do early set up, but I can't get there on Friday untill 4-430 depending on traffic.
    if that don't work out I can do early waivers and check-in.
    --Jerami Bailey--
    Jerami Bailey
    😓2013 white BRZ😓
    2013 Smurf blue frs
      --Jerami Bailey--
      I'm actually updating the post now, because I actually need at least one of the people setting up the course to give me a hand earlier in the day, and take a some time to straighten up the trailer.
      I'll put you early waivers and checkin.
        That works for me. See you then!
        Jerami Bailey
        😓2013 white BRZ😓
        2013 Smurf blue frs
Name:	Knock The Rust Off!.JPG
          What's that? Two Slaloms? A Miata will have a good chance at top PAX?
            I can come early if needed and also interested in learning something new at some point.
            Johnny (Jay)
              I can be there early enough to be a novice coach.
              Ed
                A little late to the party but can help with early work if you need anyone.
                www.alsoranracing.com
                  Can you be worker chief?
                    I'm in and can do early paddock marshall.
                      I can keep them in line. Yep, put me down for that.
                        Thanks to everyone who helped organize the event. We can't have fun without you.
                          It was good seeing you out! You are already looking very comfortable in the Miata.
                            Thanks to everyone for a good job Saturday under challenging conditions. Appreciate everyone's work and looking forward to #2.
                              Yes, the conditions were not favorable for the high HP rear wheel drive cars. You still drove pretty great in those conditions.
                              Thanks for coming out, and hope to see you out for points 2!
