Early Worker Signup - Pts 5 BPG - July 24th
  • Early Worker Signup - Pts 5 BPG - July 24th
    1. Event Chair: Steve S
    2. Course Designer: Steve S
    FRIDAY - Course setup, time to be determined. Ideally, we would start late-morning. I will update once confirmed with Barber.
    3. Course Setup 1: Nick L
    4. Course Setup 2: Sonny I
    5. Course Setup 3: Jason J
    6. Course Setup 4: Bernie M
    7. Course Setup 5: _____
    - - -Add'l Support:
    SATURDAY
    8. Early Waiver & Checkin 1: Jan P
    - - Early Waiver & Checkin 2: Erik P
    - - Early Waiver & Checkin 3: ---
    9. Trailer and Computer Setup Lead: Dwayne and Justin R
    - - - Trailer and Computer Setup Shadow and Support: _____
    10. Early Paddock Marshalls: Joshua & Ron P
    11. Safety Steward 1: Jim F
    12. Safety Steward 2: Chris C
    - - - -SSS Shadow: _____
    13. Tech Inspector 1: Kam N
    - - - Tech Inspector 2: Dale C
    - - - Tech Inspector 3: _____
    16. Worker Chief: Ed F
    16. Novice Coach 1: Tom H
    - - - Novice Coach 2: _____
    17. Late Waiver & Checkin 1: Carvel W
    - - - Late Waiver & Checkin 2: Carville W
    18. Late Paddock Marshal: Eli B
    1. _____
    2. _____
    3. _____
    4. _____
    1. Brad C - SSS Shadow
    2. _____
    3. _____
    4. _____
    • Novice Coaches should be experienced. First and second-timers will continue to be limited to about 15. Still, having two coaches would be best.
    Steve Saunders
    '18 BMW M2
    BS 72
    I can do Early/Late Paddock Marshall or Tech. I can also do starter but if possible I would prefer not to work during the event.
    Eli Burchell
    1994 Mazda Miata STR 33
    2017 Honda Accord V6 6MT STX 33
    https://www.instagram.com/205.ct2/
      SSS Shadow please
      Brad Clarke
      Something Something Miata
        I’m available for the trailer setup and timing shadow again if needed. I liked learning that
          I can do tech.
          Tom Hill
            1 Novice Coach
            2 worker chief
              Please put Joshua Price and Ron Price down for tech
                Sss
                Jim Farris
                HS Blue 1956 Triumph TR3
                DS Blue 2013 Mini Cooper S Bayswater Ed
                  Course Setup, and Novice Coach, if needed.
                  - Nick Lindsay
                    Could you sign the Webb’s up for early, lunch or late waivers, keep dad out of the heat if possible
                      Zac & I can do early setup. Zac works that Friday but will be there shortly after 5pm.
                        Early workers have been updated. If it seems that I missed you, I probably didn't. Just waiting for more information from Barber. Several positions are still open.
                        Steve Saunders
                        '18 BMW M2
                        BS 72
                          I can do something. Novice, tech, timing setup? My dad, Bruce, can do something early as well, something old guy appropriate.
                            Steve and Friday set-up crew - I will not be able to approve the course Friday aft, but will arrive before 7:00a on Sat.
                            Jim Farris
                              if you don’t need us for early setup Zac can do his usual stint at tech to fill the third spot. Just let me know where you need me.
