Fast track
  • Fast track
    Fast track is out .Mini Cooper S folks take heed .Wah hahahahahaha.It looks like the SEB is taking member input on whether to move the mini S from GS to DS.
    Full document: HTTP://www.scca.com/documents/Fastra...april-full.pdf
    Solo: HTTP://www.scca.com/documents/Fastra...april-solo.pdf
    Club: HTTP://www.scca.com/documents/Fastra...april-club.pdf
    Rally: HTTP://www.scca.com/documents/Fastra...pril-rally.pdf
    BoD: HTTP://www.scca.com/documents/Fastra...-april-bod.pdf
    Links: HTTP://www.scca.com/documents/Fastra...pril-links.pdf
    Looking for a previous copy? Click the link below to be taken there.
    Okay, I'm going to chime in ... Mini Cooper S with an LSD -- i.e. 2005 and forward should be reclassified in DS.
    A limited slip differential on a FWD car -- particularly on our course with a long sweeper at the turnaround -- makes a HUGE difference.
    My 02 Cooper S that doesn't have an LSD is at a HUGE disadvantage, compared to the 05+ models. We should make the split on the presence of an LSD or not ...
    I might even campaign hard on this one, as I might be in AL a little longer than even I expected...
    besides .. who runs in DS????
    "It's a fwont weel dwive caww ..... Fwont weel dwive" Sean Yoder ALSCCA
      Looks like chris warren can buy an 01 integra and come back to HS and whoop up.
        Yes, it looks like the newer Integras will finally move from ES to HS where they belong! Don't worry about me Cholewa. By the time I get another ride it will be a BS or AS car.
        "I'm not as think as you slow I am"
          cough SM cough
            The BS merge with CS bothers me. 350Z with Miata's. According to Edmunds, that is a 11 to 1 hp/weight for the A vs Miata at 17 to 1. Plus RX 8's...Why? Though if we do 30 sec, tight courses, it might work.
              I believe the Mini S with the turbo belong in DS and the supercharged ones are adequately classed where they are in GS.Then again if no one replies to the SEB then you wont have a say in it at all.
                Oh, SOMEONE replied...
                Peter St Pierre
                GS 63
                2007 Civic Si
