Club Class
  • Club Class
    I am pleased to announce that we will have a Club registering for the 3/29 event.
    I think this gives us some great opportunity for recruitment and retention.
    I appreciate all of you that helped with the Novice Class last event. The Club class is conducted like the Novice Class (minus the extra run). As I am sure you guys will do please help out with the Club Class. BTW the Novice Class & Club Class will not run in the same run group, so that should give other folks the opportunity to help out as instructors.
    I forgot to ask if you folks would be kind enough when you are out and about on forums to announce the Club Class. I am attaching the PDF file to this post so that you will have the correct information to put out. I would like to keep club class event scheduled. I think we need to only have 2 or maybe 3 running at each event. So lets try to corrdinate that as well.
    club class.pdf
      anytime you click on an attachment, it logs you out.
      nifty on the club class
