BRC Course Layout Template
  • BRC Course Layout Template
    Ervin, Jeremy and I spent some time Saturday night improving on a map of BRC that I'd started a while back. I think it will be a little easier to work with than the Google image we usually use for design. I'm attaching it in 3 formats ... use whatever suits your needs.
    PDF
    JPEG
    Adobe Illustrator
    yay matt got it up,
    Ervin Carder
    Wasabi Green Mazda2
    32 STF
      Also additional help would be areas of unusable asphalt and the transitions.
        Honestly, I planned to mark the broken up areas, but was told yesterday that we didn't need them. If I get more requests, I'll plan to do that during the next event.
        The hump areas are easy to spot as they are the lanes passing through the lot. You can find them based on where the road passes through the islands. However, if this is needed, I can add as well.
          It's been awhile since I've set up a course down there but I remember some hump areas being worse than others. You've got a great map going.
            Thanks for the hard work Matt etal. I really appreciate the help. I copied your first post to the map section so that it does not get lost.
              Thanks Jamie.
