Points #1 Worker Thread
    Safety
    Co-driver and/or I can do safety on 4 April, as needed.
    J. Wetzel
    AS 97
      I have to miss this one ... I'll be out of town visiting family, it being a holiday and all.
        Would it be possible to shadow on safety stewart and help my daughter in the pits with her kart?
        Brandon Roberts
        Lotus Seven replica - Yamaha R1, book chasis
        Lola T-640/644 - GSXR 1000
        Extreme Kart - Briggs & Stratton World Formula
        Birel B25 - Comer C-51
          We can make that work; however, I need to know your name (it's not in your signature) and if you have taken the safety steward class.
          Sam Copeland
          Nissan 350Z BSP 2
          www.RedvsBlackRacing.com
            Originally posted by SamC View Post
            This is the worker thread for points event #1 that will be held on Saturday, April 4th at Oak Mountain Amphitheater.
            Tech Inspection / 7:30a
            (if you have not worked Tech before you must first talk with Heath, Sam, or Mark)
            #1 Heath Patterson
            #2
            Put me down for Tech with Heath.
            Tanner Powell
              Brandon and no, I seem to have missed the safety class at the last event. In any case I figured i could help and learn a bit myself since I wont be running at this event.
              Brandon Roberts
                We appreciate the offer but shadowing safety is a position for those that have taken the Safety Steward class and have to get their required number of shadows in before being licensed. Your work assignment may end up helping the safety steward in some way but it is not the same as one of the shadow positions.
                Since your daughter is coming, do you know if there will be a youth steward at the event?
                  As for the youth steward attending I do not know. I was instructed to post her intent to participate in the event thread before each event and I have done so and received no reply. I inquired about the safety steward class at the test n tune and hung out by the timing trailer waiting for the class to start but nobody ever announced anything so I left that day somewhat confused.
                  Brandon Roberts
                  • #24
                    Hi Brandon - I am a Youth Steward and plan to be at the event on Saturday. I will fill you in on what is needed to become a Youth Steward, which is less complex than becoming a "normal" Solo Safety Steward (not that we have any normal ones). I'll be looking for you in the morning to go over some important items with you and your daughter. FYI my name is Andrew Reynolds and I live "up North" in Huntsville.
                    As previously posted, please make sure the kart has a redundant brake cable and a kill switch within easy reach of the driver (must demonstrate the ability to turn off the engine). Other critical items below:
                    G. Driver Safety Equipment
                    1. Neck Braces: An unaltered, collar type neck brace designed for motor
                    sports use, is mandatory. Kart-specific neck braces are recommended.
                    2. Driver Apparel: Drivers are minimally required to wear jackets
                    of leather, vinyl, or abrasion resistant nylon or equivalent, and full
                    length pants to prevent or minimize abrasions. Full abrasion kart
                    suits are recommended. Shoes, socks, and abrasion resistant gloves
                    are mandatory.
                    3. Seat Positioning: When normally positioned in the kart for competition,
                    the entirety of the driver shall be within the perimeter of the
                    154 — 2015 SCCA® National Solo® Rules
                    19. Kart
                    kart and the driver must be able to reach and operate all controls.
                    Loose cushions or pads that prevent the driver from being adequately
                    supported by the sides of the seat are not allowed.
                    E. Safety Equipment
                    1. Must follow Section 19.1.G. In addition to meeting the requirements
                    of Section 4.3.1, helmets for Formula Junior drivers must be of closed
                    face design, incorporating full face shields and chin bars.
                    2. Kill Switch: All drivers must demonstrate the ability to shut down
                    the engine both while driving and stationary. It is suggested that the
                    kart have an operational ignition kill switch within easy reach of the
                    driver in the normal operating position.
                    3. Seats: It is not permissible to use any type of strap or seat belt. In
                    the event a kart is upset, a driver must be able to exit the kart unrestrained
                    by a seat belt or strap. It is recommended to utilize some
                    form of seat insert and pedal extensions to fit drivers of different
                    sizes to one seat.
                    4. A “brake safety cable” or redundant brake pedal connection is required
                    in all karts.
                    Feel free to PM me with any questions.
                    Andrew Reynolds
                    TVR Youth Steward
                    1994 Mazda Miata Turbo Black SSM #0 (Autox)
                    1999 Mazda Miata SC Greenish MR #0 (RallyX)
                    • #25
                      If I remember right the Safety Steward class was just finishing up when you arrived at the trailer. A brief announcement was made that morning but our PA system doesn't reach the entire area. It's likely you didn't hear it. There may have also been some confusion regarding whether you wanted to attend a Safety Steward class or become a Youth Steward.
                      • #26
                        Excellent, thanks for the reply Andrew. I'll be there bright and early then. We will go over her kart again this week and weather permitting see if we can get in some parking lot practice time for her. @John, I do remember he PA was a bit on the quite side. I just figured I missed the announcement for some reason or another. Thank you for the clarification.
                        Brandon Roberts
                        • #27
                          No need to be super early as I'll be traveling down from Huntsville and won't arrive until 8:30 or so. See you Saturday!
                          Andrew
                          Andrew Reynolds
                          TVR Youth Steward
                          • #28
                            I will be there to help with course setup
                            • #29
                              Easter Conflict. I'm out.
                              John Allen 52BS
                              TVR/TAC/ALSCCA
                              People under 50 don't deserve to have this much fun! :-)
                              www.marketing-ontheweb.com
                              • #30
                                Ok, thanks for letting us know John
