SM engine allowance rule discussion
  • SM engine allowance rule discussion
    I ha this conversation on Facebook today and wanted to see how you all feel about it. It's about engine swaps in SM.
    The rulebook says this:
    "D. Drivetrain and related components (induction, ignition, fuel systems,
    etc.) are unrestricted except for the following limitations:
    1. Engine block (or housings of rotary engines) must be a production
    unit manufactured and badged the same as the original standard
    or optional engine for that model. Badges that exist as marketing
    aliases for the manufacturer will be recognized as equivalents.
    Swaps involving makes related only at a corporate level are not recognized
    as equivalents. Models produced as a joint venture between
    manufacturers may utilize any engine from any partner in the joint
    venture, provided that an engine from the desired manufacturer
    was a factory option in that particular model (e.g., Eagle Talon, available
    originally with either a Mitsubishi or Chrysler engine, may use
    any motor from Chrysler or Mitsubishi). This allows engine blocks
    manufactured as production units for sale in other countries such as
    Japan or Germany."
    (emphasis mine)
    But, we know that there are 3-rotor RX7s running SSM at the national level. The 20B was never offered in an RX-7, only the Cosmo ... obviously a different model.
    So, I looked on p 66 to see how the SCCA defines "model."
    "Model
    A group of cars of a given make which have virtually identical bodies and
    chassis but are readily distinguished from other models of the same make
    by virtue of a major difference in body appearance and/or chassis design.
    The names by which the manufacturer designates these groups have no
    bearing on this definition even though two (2) groups may be designated
    identically"
    That's pretty clear. A Cosmo isn't an RX-7.
    So, the basic understanding of engine swaps in SM is that any engine from that manufacturer, or from a manufacturer within a joint venture (DSM, etc) can be used. To me it seems pretty clear that the rule says it has to be an engine offered in that specific model.
    The easy example is from a DSM. My interpretation says that you can only use the engines available in the NA or turbo models of the Eclipse, Talon or Laser in those cars. But, if you have an Eclipse, you can use the Laser engine, etc.
    The other interpretation is that if you have an Eclipse you can use a big block from a classic Challenger.
    The much more likely scenario is that you could use an RB25/26 or V8 from the Titan, etc. in a 240. The 20B in an RX-7 or Miata.
    It seems to me that logically the "all engines from manufacturer" interpretation makes sense. But, the rule clearly doesn't say that IMO. I think it needs to be rewritten to remove all mentions of "model" if this is truly the spirit of the rule.
    We've had this exact discussion before. I think this rule is about as clear as it gets in SCCA land
    It says exactly this...
      Then why does it state "that (particular) model?"
        For the same reason it did last time we did this...
        because it refers to the car that is receiving the swap, not the swapped in engine. The swapped in engine must be "a production unit manufactured and badged the same"...badged the same as what... "as the original standard or optional engine for that model".
        It doesn't say the engine has to be the same as one for that model...it says the engine must be badged the same as one offered for that model.
        If your interpretation was correct almost all of the SMF Hondas that dominate national events would be illegal, as would most of the SM & SSM fields. And if it was correct someone would enter a bone stock rental Focus in SMF, protest the entire field, and walk away national champion
          Rod is correct in that the term "badging" is the significant language. Unfortunately, the rules do not clearly layout what "badging" means. I'll use an example to try and explain it with a car that I know. A 1989 BMW 325i came with the Inline 6 motor, which is manufactured and "badged" as a BMW engine. The motor is a M20b25 engine, but its badging is just simply BMW.
          Hence why an Eagle talon can take ANY engine from Chrysler or Mitsubishi because the engines that were available in the joint venture were "badged" as either a Chrysler or Mitsubishi engines. The specific engine used is not relevant. The badging refers simply to the engine maker, and thus the specific engine model is too narrow of an interpretation of the rule.
          Another example, the Scion FR-S and Subaru BRZ both use the same engine that is badged as a Subaru engine. Thus if you have a Scion FR-S or Subaru BRZ, you can swap in ANY Subaru badged engine.
          Now lets say that the Scion/Subaru car was available with EITHER a Toyota 4 cyl, or a Subaru Boxer engine as options. That means the cars were supplied with engines that are badged as Toyota or Subaru. Therefore, you could swap in ANY Subaru engine, or ANY Toyota engine.
            Okay, that makes sense. Thanks.
              So, now that this is settled, again
              Hmmm... the new Minis finally have a BMW sourced engine. I wonder 1) if the motor is badged "BMW" and 2) if the old M3 V8 will fit
                I also thought it had to be an option for the specific model. But it's too dern grey in there. If it's badged for that model ...not badged as an entire make of cars. That was what I thought. But I hate the rule book. So.
                Put a dern big turbo tuned Duramax in a Chevy Sonic. ALL the friggin Torques. All of em.
                Heath Patterson
                  I'm thinking 2JZ Evora.
                    Now you're talking!
                    Makes you wonder if Lotus would leave "Toyota" badged on the stock engine.
                    How 'bout 2JZ Elise?
