numbers?
  • numbers?
    Another noobie question...are numbers class-specific? For example, can there be a "10" in multiple classes? I'm assuming this is the case, so I should be safe with whatever number I pick in the new N classes.
    Thanks!
    f you are running N, you will still be put in a class like BS or SM ... you will just be noted as NBS or NSM. The N is only a PAX modifier. There can't be a 10 NBS and a 10 BS.
    So, you need to choose a number that will fit in the actual class you will be running. Basically, you want to be able to keep the number for next season ...
