Sure Sam, dream on. Since the Blytheville Tour is Oct 18-19, I guess Red vs. Black racing is not running the South leg?
Thoughts for NvS
Since the event has been moved we are not going to Blytheville this year. So we will be at the local event. With the money I save from not going, I'm building a tire trailer so i can be more prepared to travel next year.Originally posted by mpcavana View PostSure Sam, dream on. Since the Blytheville Tour is Oct 18-19, I guess Red vs. Black racing is not running the South leg?
I will be glad to help with tire trailer ideas. I have built and modified severalOriginally posted by SamC View PostSince the event has been moved we are not going to Blytheville this year. So we will be at the local event. With the money I save from not going, I'm building a tire trailer so i can be more prepared to travel next year.Bill Clinton "It depends on what the meaning of the word 'is' is."
Fixed that for you...Originally posted by claym View PostI will be glad to help with tire trailer ideas. I have built and modified several (with a lot of help from some body that knows what they are doing)
Thanks, I am probably going to purchase John Allen's trailer and will have to modify it to fit my tires. I'm open to ideas.Originally posted by claym View PostI will be glad to help with tire trailer ideas. I have built and modified several
You've seen my trailer. I had to stack my tires as they won't fit between the fenders in the orientation on that picture. I also had to build a base to get the tires above the fenders so they would fit stacking them. In the center I have a metal pipe that is bolted to the floor of the trailer. Around that I have PVC to keep from damaging the wheel centers. I then use a strap to keep them from jumping off the trailer. Both ends of the straps go to points that are through the trailers frame so you can really tighten them down.
I feel like with the tires at the back there might not be enough tongue weight on the trailer which causes it to bounce a little bit more than normal. I adjusted that by getting a new hitch that allows the trailer to slant forward towards the car for a little added tongue weight. I've read online that a lot of people take one leaf out of the leaf spring to keep it from bouncing. This is fine since we're really no where near the max load for the trailer. I might try doing that to mine over the winter.
If I was to do it again I'd probably put the tires on the front and tool box in the back. I had it that way with my E30 but switched thinking loading/unloading would be easier from the back. It really doesn't make much difference once the trailer is disconnected from the car and I felt the trailer bounced a lot less on the E30 vs the M3.- Jerry Ledford
I have the same trailer and had a similar setup to John's, but then I removed the box and just put the 4 wheels evenly distributed across the trailer, lying flat. I did have to build up the floor above the fenders as Jerry did, but it's simple to get the tires on/off and the trailer is very balanced. No issues towing.
I found that I really didn't need the box as the few things I bring can fit in the trunk.Andrew Reynolds
TVR Youth Steward
1994 Mazda Miata Turbo Black SSM #0 (Autox)
1999 Mazda Miata SC Greenish MR #0 (RallyX)
