Points 5 Sunday August 17 Worker Thread
  • Points 5 Sunday August 17 Worker Thread
    This is the worker thread for Points 5 Solo event that will be held on Sunday, August 17 at Oak Mountain Amphitheater.
    As always, we need people to show up early and help us clean up and set up.
    Event is at Oak Mountain Amphitheater.
    Gates open at 7:30, on-site registration/check-in lasts until 9:00, and first car off at 9:30.
    If you have any questions, please contact Mark Kilgore, or myself, John Kilgore and we will try to answer.
    Devotion / 9:15a Jeremiah
    Early Set Up / 6:30a
    #1 Event Chair: Mark and John Kilgore
    #2 Course Designer: Clay McCool
    #3 Set Up (x3): Steven Vanzant / Charles D'Ambrose /
    Timing and scoring (4 workers): Rob Arbitelle / Rod Hardiman /
    Registration 7:30a
    Pre-Registrar/Check-in: Josh Bassett
    Onsite-Registrar: Delanie Calhoun
    Cashier:
    Waiver station / 7:00a to 8:30 am (worker assignment for the day)
    #1 Jerry Ledford
    Waiver Station / 8:15am to drivers meeting (worker assignment for the day)
    #2 Ben Hardiman
    Tech Inspection / 7:30a
    (if you have not worked Tech before you must first talk with Heath, John, or Mark)
    #1 Heath Patterson
    #2 Zac Hardiman
    Safety Steward / 7:30a We need 2 minimum (make sure you get your shadows in)
    #1 Sam Copeland
    #2 Jim Farris
    shadowing : Andrew Reynolds
    shadowing :
    Novice Directors / 8:30a
    #1 Sara Tongsuvone
    #2 Chaisit Tongsuvone
    Blower: Lyle Cain
    __________________
    Fortuitous time to check the forum
    The usual if you please..
    Ben: 2nd shift early waiver
    Zac: tech
    Rod: T&S
      Setup please.
      Steven Vanzant
      2004 Sebring Silver S2000
      STR 16
        Safety
        Sam Copeland
        Nissan 350Z BSP 2
        www.RedvsBlackRacing.com
          Registration please.
          Josh Bassett
          Black 1994 Miata
          CSP 49
            Setup please!
            Charley D'Ambrose
            Boy I remember the first time I got shot out of a cannon!
            '04 Pure White Mazda Miata - STR 77
              Early waivers!
                I am working on my SSS license and would appreciate working as a SSS Shadow please.
                Thanks,
                Andrew
                Andrew Reynolds
                TVR Youth Steward
                1994 Mazda Miata Turbo Black SSM #0 (Autox)
                1999 Mazda Miata SC Greenish MR #0 (RallyX)
                  I can do SSS. (see newer post re:Jim Farris)
                  John Allen 52BS
                  TVR/TAC/ALSCCA
                  People under 50 don't deserve to have this much fun! :-)
                  www.marketing-ontheweb.com
                    I can assist with registration.
                      The usual
                        I can do course design if needed. Got another idea....
                          Devotions
                            Jim Farris says he needs another event to keep his SSS so I'll bow out. I will be there if you need an alternate (or a third) SSS.
                            John Allen 52BS
                            TVR/TAC/ALSCCA
                              Yes, what John said!
                              Jim Farris
                              HS Blue 1956 Triumph TR3
                              DS Blue 2013 Mini Cooper S Bayswater Ed
